sledrescue
The only problem with Mothers is you will go through it too fast because you have to use quite a bit to get results and Mothers is just a polish so it doesn't seal the surface when you are finished. Another thing with Mothers is it keeps smearing black and you have to use flour to get the stuff off. I have seen the same thing with Wizards.
You will definitely be impressed with the results from White Diamond and how easy it is to use. With lasting results.
