Well, one thing's for certain--Wisconsin's continuing confusion over the use of turn arrows vs. curve ahead warning signs is very much alive and well. Of course is doesn't help that the current Wisconsin snowmobile trail signing handbook shows on page 4 that "Directional arrows should.....and be placed in advance of the turn....." Presently some clubs and counties are doing just that--using directional arrows (turn-arrow signs, those little rectangular 6"X12" signs) in place of a uniform diamond shaped 12"X12" warning sign. Guide signs such as directional arrows or chevrons are always rectangular or square and direct snowmobiles to make a sharp or gradual turn or curve to the left or right. They should be placed AT THE CURVE OR TURN, and snowmobiles turn IN FRONT OF those signs. If the curve or turn requires advance notification, then a WARNING SIGN (a yellow diamond shaped sign)--an arrow with a leg--should be used at some distance prior to reaching the turn point. The same uniform signing techniques that are used nation-wide for marking roadways and highways are usually followed for snowmobile trails. This means red octagon signs for stop signs, yellow diamond shaped signs for warnings of an approaching situation such as bridge ahead, stop ahead, curve ahead, intersection ahead, etc. etc.
Not sure how this problem somehow slipped by the trail signing handbook proofreaders, but it did, and it is still a Wisconsin problem out there on the trails.
Don't bash me too hard on this. I am merely making this post as a mindful "please be aware" notice. It is a safety concern for snowmobilers. We must keep in mind that the arrow vs. turn-ahead warning sign placement is a continuing problem in Wisconsin and that the placement of these signs is NOT uniform as we ride between different counties and club segments on our trail system.
