I would recommend one that offers a quick attach front mount system. The push tube set ups are easily tweaked (bent). Check out Cycle Country or Moose. I am not sure if Moose offers one with a quick attach or not, had one with the push tube set up, too much torque on the push tubes. Cycle Country did a while back. If you end up having to go with a push tube frame, make sure it is one that is not real long, the longer the frame, the easier it is to bend. Believe me, it's not flimsy, but if you hook into a heavy load, the power of the ATV will win over the push tube every time.-Mezz
I'm sorry to say this, but your 100% wrong, if you look on any Plow makers own site they list the push tube set up as being there strongest set up they make and sell
I have pushed literately 100+ ton of gravel with my push tubes and there fine
as long as there a decent quality design
I once hit a steel bean sticking up about 5 inches at about 25 mph plowing, sheared off two boalts and never damaged the push tubes, almost went over the bars when teh rear wheels cme off the ground, had some nasty black and blue marks on my thigh when they hit the bars and was VERY glad I was wearing a helmet when my head hit the rack
MY fault for going so fast
but my plow's push tubes never budged
I did dent the back of the blade from the push tubes when the bolts there sheared off and hit the back of the blade
BUT push tube set ups from Moose and CC are the strongest set up they sell
they say so on there web site 's too!
here is OFF cycle country's web site
<tbody style="box-sizing: border-box; margin: 0px; padding: 0px;">
</tbody>
Thanks for the opinions on winch lines. What size winch should I go with for plowing with a 60" plow? Going to look at a 2016 Grizzly 700 EPS SE today. Pretty good deals with the 17s out. Any thoughts on a particular plow brand or set up? Thanks!
due to the weight of the ATV< a min to me would be a 2500 lb winch, general rule of thumb on winches is you need twice the LB in winch as the whole vehicle weighs with you in/on it and all your gear, I like to add a little extra to that number, cause when your stuck in say deep much the vacuum it can get a hold of your atv and make it feel a LOT heavier
so, at least a 2500 lb, 3k-3500 wouldn;t hurt either if ever stuck and there all about the same size in this range
if strictly plowing only, you can go lighter, but most 2500 winches can be had for darn near what a lesser one
same can be said many times for a 2500-3,000 lb model,
seem many times where the 3k is like 10 bucks more only?
and worth that 10 bucks too if your ever stuck LOL
