Here is one of my posts from a previous thread about adding oil in the gas tank;
This is completely incorrect. You will not burndown an engine because of to much oil. 2-stroke oil is meant to MIX with gasoline. Also, if you do happen to dump 3 gallons of oil in with 6 gallons of gas, your plugs will foul before your pistons have a chance to even get anywhere near up to temperature. And if for some ungodly reason your plugs didnt foul, and your injectors didnt plug up, you in cylinder temps would never get anywhere near 1200*F because oil burns alot slower than gas. No explosion, no heat. The only way you could possibly run that much oil, is to have extremely high compression ratio, like that of a diesel engine. And with ports instead of valves in the engine, that aint gonna happen.
Alot of BS in this thread.
Running pre-mix in a new, or rebuilt machine for the first tank to check to make sure the oil pump is working properly is a great idea. However, it does not help seat the rings. If you want to seat the rings properly, take it out and beat the snot out of it for a little while. Get it fully up to temp, no WOT for long distances, no steady throttle for long distances, just up and down the RPM range constantly. Get er good and warm, and let it sit over night to cool completely. Thats the proper way.
Having said all that, the manufacturers are not going rely on the consumers to PROPERLY break in the engine. You can do pretty much do whatever you want to them, and MOST of the time you will be fine. I dont know for a fact, but I suspect the engines are all ran for at least a few minutes before they leave the factory.
