Under 11000 miles blew piston on pto side. Rebuilt completly, crank, pistons, seals., carb boots. about 100 miles blew the same piston. Melt down on exhaust side ( cold burn?) Could coils or cdi cause this? Carbs cleaned, oil pump primed at rebuild. Talked to a buddy who is Polaris mechanic said he's got one in the shop doing the same thing, same piston. Said he's built hundreds of these 600 triple over the years and this is the first time he had this problem. Any one else have this problem ?, and what did you find that caused it? Any help much appreciated. Thanks
