fyi......................
Myth #10 - You can't use motor oil in a manual transmission.
Fact: Fluids recommended for manual transmissions/transaxles vary from manufacturer to manufacturer and are dependent upon application. The type of fluid recommended for a given unit will depend on a number of variables which include the low temperature fluidity required, the amount of gear wear protection needed, the effects of the fluid on synchronizers and the transmission/transaxle. Some transmission manufacturers may require motor oil to be used in the manual transmission. Other fluids used may be ATF, gear oil or a special manual transmission fluid, depending on variables previously mentioned. Always check the owner’s manual to ensure the fluid being used has the proper performance requirements.
Myth #11 - Oil is oil … ATF is ATF. All oils are the same.
Fact: Motor oils and Automatic Transmission Fluids (ATF) are formulated differently. Motor oil is formulated to withstand the harsh combustion environment of an engine, while ATF is formulated to provide specific properties for a transmission.
Myth #12 - Adding a quart of ATF the day before an oil change will clean your engine. ATF added to the motor oil will clean the engine due to the high levels of detergent in ATF.
Fact: ATF does not contain detergent chemistry. ATF does contain dispersants, which have properties similar to detergents. But ATF is not formulated to withstand the combustion environment inside the engine. Havoline recommends that you keep the fluids where they belong: motor oil in the crankcase, and automatic transmission fluid in the transmission.
