sweeperguy
Never had anything in way of pulling exhaust valves.
Went to pull them to clean on my RMK 600. Mag side no problem, bit the PTO side hits the lower steering post. (Pitman arm?). If I take out the 2 bolts holding it to the upper structure and disconnect the link arm, will it move enough to get the valve out. Or will I need to unbolt the tie rod and cross link on the bottom?
