Clutch rebuilding in SE MI
jccams
Anyone know of someone that does clutch work in SE MI? I have a P85 primary that I would like to have rebuilt, buttons, bushings, check rollers, etc.
I sent mine off several years ago to get done and was very happy with them! I just can't come up with the name right now. I will post if I come up with it.
What is a typical charge for a clutch rebuild? Do you have both clutches rebuilt? How often should this be done?
Goodwin Performance is where I sent mine. I can't remember what it cost me, it was 5 years ago or so with 7,000 miles on it. Visit their website or give them a call for more info. Now is the time to do it before they get swamped!
Depends on how hard you ride the sled. Typically between 5-8000 the clutch is on borrowed time I'd say. Heck my 08 RMK clutch looked brand new except for 1 completely junk roller with missing shims on each side with less than 1000 miles on it, It looks to me like it was put together at the factory without the shims, and I tore it apart tonight for my buddy who bought it from me, spider might be junk also. I think a dealer a few years back wanted $250-300 to rebuild my dads clutch on his sled. I now have all the tools to do it for less than $200, rebuild kits run around $100.
I assume you need a clutch puller tool specific to that clutch to get it off (the primary)? I will be driving right by Goodwin's Monday but I am not sure where I can get a puller by then
I called a couple dealers and it looks like the clutch pulling tool is about $60. Is there any way around buying this?
I got mine for $40 from epi. Some have packed the hole with grease and tightened the clutch bolt and popped it off. Not saying it will work but have heard it's been done.
The epi one is now $60 from the few places I checked. I didn't look around too much, as I was trying to find something I could buy by Saturday, as I'll be driving right by Goodwin's on Monday and Friday, so I thought it might work to drop my clutch off with them. I think I'll be doing the same thing in October for work again so I will probably just wait till then to figure it out. I saw that grease or water method today, but I'm not sure it would work well for a 9 year old sled that hasn't had the clutch off before.
joshwagner
The only issue with using grease is that its, well, grease. Water and thread tape works well but the last time I did it I used cheap brandy, it was too cold and the water would have frozen on the cold clutch. That trick works especially well on the newer on SkiDoo's because the threads in the clutch match the threads in the output shaft. YMMV.
If you don't have that luxury (and I don't think you do), you'll need a bolt with threads that match the puller threads inside your clutch. Fill the bolt hole with water, wrap the threads with teflon tape - plenty, then put the sled on its side and thread your new bolt into the clutch (not the output shaft) and start tightening. It might take a couple of tries but you'll enjoy the very loud pop when you get it right. You might need a long handle wrench or breaker bar for the last couple of spins. Youtube it for your machine "water clutch removal"
+1 on goodwin. They know their stuff and with the press-fit graphite bushing on the doo's its worth not making a return trip after you've broken it.
Josh
rp7x
one puller does not fit all Polaris , never use a impact , much easer with smoke and mirrors , just buy a good puller , priceless
Thanks. The EPI one is the one the closest two Polaris dealers have on stock, so I'm assuming that's the go-to one for now.
I have 2 EPI pullers, very good quality. I would not buy a cheap one, if it wasn't heat treated properly it will break off and you'll need a new crankshaft. Much cheaper to spend an extra $20 or so on a good puller. I use a 2' breaker bar and a wood dowel to hold the clutch, sometimes takes 2 people. I have used grease a few times on older sleds works awesome, can of brake cleaner and some compressed air cleans it right up. Never tried water.
toss the sled in the truck and use goodwins puller if only doing this 1 time takes about 1 min to do.
D.B. Cooper
There's one on amazon that says it will work for all Polaris sleds for $20..might try that.
http://www.amazon.com/Polaris-28705...laris+snowmobile+clutch+puller#productDetails
Before you buy that cheap P.O.S.^^^^ that might mess up the end of your crank;
MOST POLARIS Clutches have a 3/4" thread in them.
For an inexpensive clutch puller, Go to the local hardware store, purchase a 3/4" FINE Thread hardened bolt approx 1-1/2" - 2" long and wrap some Teflon tape around the threads.
Then fill the clutch bolt hole with water / oil / grease and tip the sled on its' side and remove it hydraulically.
NO pressure metal/metal contact on end of crank this way
There are SEVERAL different pullers for the POLARIS sleds, check the S.L.P. or HiPerf engineering website for applications/interchangability
The genuine POLARIS (made by SPX) tool for the DRAGON/IQ/RUSH/PRO is approx $ 50. Bought one several years ago, still works/acts like new
Ended up buying an slp puller for $40. Dropped the clutches off at Goodwin today on way to Milwaukee for work...not hard at all to remove clutch with proper tool
