jerkbait_1075
Good advice about waiting to finish instead of playing catch up. Not only from the finish appearance but "playing catch up" and working the surface in desperation can lead to a whole nother multitude of problems. Yes this time of year accelerator is an option/necessity. Two things: First if you are using any type of reinforcement steel or wire mesh then I would strongly reccommend a "non corrosive" accelerator. WR Grace Company makes a product called DCI that is a non corrosive set accelerator. There are many other manufactures with similar products. We strictly use WR Grace products. Most ready mixes would simply give a contractor or do it ur selfer Calcium Chloride for a set accelerator. The problem with calcium chloride is that it is corrosive and will eventually "eat away" you re rod or wire mess. The option to steel is to use a reinforcing Fiber mesh. However fiber mesh will also show small fibers in the surface of the concrete. Its personal preference but I like the fibermesh and the fibers are very hard to see and do wear away. Second option. Is to avoid the accelerator all together and use Hot Water in the mix at the time its bathced. Now this can be a difficult task for do it urselfers as Hot water can be a very unpredictable animal and concrete can get "away" from you finishing wise in a hurry. Also if the ground temp is 40-45 or lower, or the aggregate temp of the material piles at the ready mix plant are below that temp you really need to use hot water. If this is an outside slab, or cold storage and you live in an area where temps are going to be at and below freezing routinly from here on out you need to get the process of curing going and keep it going. Your new slab is not going to be safe from the dangers of freezing temps for at least 21-28 days. Keep that in mind. If the temps are going to be low you may want to consider keeping the slab covered. Once finished, straw, styrofoam, frost blankets are all options. However if it is to turn warm or moderatly warm again it is equally important to remove these covers so you dont over heat the curing process.
Concrete is a tricky animal.... Lots of factors at play..... Good luck
