Tighten the limiter strap(s) 1 hole, back off on the center spring preload a little, increase ski pressure, if it has coupler blocks on the skid ??? move them to the thickest setting to try to decrease the transfer. I agree with the above posts, try to tune it before you throw money at it. The skags are a balancing act that sometimes will require studs also. Make 1 change / adjustment at a time. I would think that sled would corner great due to it's profile. But that is a guess, I thought the 4 stroke Yami's would corner well due to all the weight also but that is not the case. Some riding patrners have a couple of those ( x-fires )and they never said a word about those not handling good in the corners ? Bergstroms are as good as they say, so are shaper bars.
