I'm the lucky guy with the Pol 600 that appeared to have a burndown last weekend. Dealer just called. No burndown - mag side exhaust valve broke and took out the piston. The pieces of aluminum that I found on the spark plug came from the chunk that was bouncing around in the combustion chamber. This also explains why I could not rotate the engine, there was a piece wedged in place.
Service mgr said the carbs are clean (good!) and the other piston looks OK, but is at the 'service limit' so both pistons will be replaced. The cylinder and head wasn't harmed which is good (the cylinders are really pricey, too!).
I did pull the valves in the fall and gently cleaned them. They didn't have much residue on them and they were only out of the sled for 10 minutes. I didn't drop either one. Really strange. I have pulled the values on our older Liberty 600 many a time and they are fine at 5000 miles. The dealer said they have never seen a broken exhaust value on a 600. I have read about Pol 800' s having that problem several years ago, but only the 800. Plus this engine only has 2500 miles. It's a 2005 so it's not that old.
The bad news, this is even more expensive than a burndown! Two exhaust values plus all the normal rebuild goodies (pistons, rings, seals, labor) adds up pretty quickly. The good news is the engine will be fresh (and hopefully ready to go).
Perhaps a small moral victory knowing that a lack of maintenance didn't cause the problem.....but I'm still staying away from "Iso Al" in the future!
