winter_time
alright can you call the dealership for me and let them know that your diesel gets this then ill go pick one of these up
can you see if he has another one i would really like one of these but i would like it in white with black rims
tell him to give it a white paint job maybe add a black strip along the bottom and then ill be interested
it would be really sweet if it had the 10 cylinder triton in it then too because the gasser is more of a financial benefit than the diesel in my opinion
I went from a diesel back to a gasser. Part of the reason was the 4.10 gears it had and the other part is I couldn't justify owning a diesel for the limited towing I do. Driving on the highway I get 18mpg or so doing 70-75 with my 5.3 gasser that is plenty for me. When I cruised the 4.10 diesel at this speed I got less than 16mpg. I had slightly bigger tires on it too but it didn't help much. If you tow a lot I'd get the diesel BUT make sure it has 3.73 gears or higher (meaning a lower lower number).
i am currently getting 16 miles to the gallon on my 5.4 l v8 in a f 250 running 33s
BTW changing oil is the same as a gasser, changing filter is easy too. Otherwise, put a new belt on it, like a gasser, every once in awhile and run it. Dont use K&N oiled air filters on diesels, bad for the turbo and engine.
What is involved in this fix?It was prone to overheat on hard pulls, but it is a intake air design flaw, and is easily and cheapy fixed by a do-it-yourself'er at home.
No engines like a mile long commute, especially diesels.
Installed 37" toya's on our dually diesel to keep the rpm's down ,4" SS straight dual exhaust ,superchips programer and K&N .Its a beastWhy would you not use a K&N on a diesel? I have over 50k on my K&N with no problems on my D-max. What proof do you have that they are bad for diesels. K&N is a well known manufacturer of quality products and if there was proof that their product was bad for an aplication, I would think they would do something about it. Back to the subjuct now, I will probably never go back to a gasser after owning a D-max with the Alison tranny. My 06 has the 6 speed and I can get as high as 23.3 mpg depending on speed. Normaly tho a constant 17 to 19 running empty at 65 to 70. Pulling my 38 foot Montana fithwheel at 55 to 60 to the Hodag last year we got 14.3 mpg. When we went out west pulling a Triton inline, bucking wind at 70 to 75 we got 10 to 12 mpg's. I found rpm is everything, if I keep the rpm between 1500 to 1700 max I get great mpg's. Anything over 1700 rpm and the mpg's start to suffer. My dealer does my oil changes at about 70 bucks, (gotta remember 10 qts oil) every 5000, fuel filter in the fall at about 80 bucks. I feel the extra cost is well worth it considering the awesome power and torque that a diesel brings to the table. That isn't even counting the better trade/resale value. And the higher fuel price is is negated by the better mpg's as stated in a previous post. Good luck in your decision.
Last spring I switched from a 6.0 gas to a 2007 Duramax. No regrets in the change.
Mileage is better empty and towing. Lucky to get 14mpg empty with the 6.0 and now get 16 to 17 with a mix of city and hwy. Best I've gotten with the Duramax was 21mpg on summer fuel going 65mph all hwy. The 6.0 would get 7.5 to 8 towing my travel trailer but the Dmax gets 10 to 11. The thing I like the most about the Dmax is you can set the cruise no matter what your towing and it will pull it. Driving the gasser would wear me out on long trips towing. All the downshifting for hills would drive me nuts so I'd leave the cruise off and let it slow down on the hills. I agree with the others that maintenance is more but it's worth it.
Recommend that you get diesel fuel from a station that pumps a lot of it. (truck stop etc.)
It'll cut down on your chances of getting bad fuel - one downside of a diesel. Always keep one if not two extra fuel filters behind the seat and a bottle of 911. Having that along with the filter wrenches during the winter time will save your butt if the truck gels during the winter.
duramaxforum.com and dieselplace.com are great sites with tons of info.
If you use the truck primary for towing, diesel is the way to go. The Duramax is a wonderful engine. Had a 2001 and loved it for towing. Fuel price is of coarse now higher than before the low sulfur came to the US. Oil changes are going to cost more, dealers charge around $90 now. Bottom line is you buy a diesel for the power, not the fuel economy. The extra cost of fuel, and maintenance will soak up your fuel savings. Now for towing, you would not be disappointed with the Duramax. I used to tow a Dutchman 5th wheel, triple slide outs, Garage in the back with two sportsman 500's. Never a complaint for lack of power.
