I make my own digital TV antennas. I used some good quality heavier speaker wire I had laying around. Anywhere from 2 feet to 10 feet. I pulled the two wires apart for a bit, forming a "T". On the bottom end of the T, I attached one of those old small two wire to coax adapters that were used to hook rabbit ears into the back of TV's. I use a short one to take a TV outside, or in the garage. My house is prewired for satellite, so I made a longer one, went up in the attic, found the satellite feed, connected into that, and stapled the speaker wire to the rafters in the attic. Now each TV simply hooks up to the satellite wall jack in each room and gets over the air signal. I did add a cheap signal booster to the longest run in the house. I live rather close to town, so I can't attest to how this may work in rural areas.
