tubbywolfe
Bolt holding on bottom gear sheared off, am I ok drilling out the bolt that is left in so I can fix it all up? If not, how do we get that snapped of bolt out of there?
Thanks
Thanks
just experienced the same problem on my edge we just sold today. I tried to drill with and angled drill and use an ez-out but it was a no go. The problem is that you cant get a good angle to drill it straight. If I knew how easy it was to remove the driveshaft on an edge compared to my xcr, no question I would have done that after the first failed attempt at the ez-out. When out I just kept steping up on the bits till it came out and rethreaded it. One thing I should have done was to go up a size on the bolt to prevent the problem.
