dfattack
May want to consider a NEO or an RnR.
Both built in Michigan. NEO would be the better of the two. Very good quality fit and finish.
Legend built in Michigan too. I have a 29' trackmaster from them and am happy with it.
One thing that I know that someone incorrectly mentioned above - as far as the width of the axles 7 wide vs. 7 1/2 wide vs. 8 1/2 wide ( NOT deckover ) - most that I know of, the OVERALL width of the trailer is the same. Meaning that the overall outside dimension of the fenders/tires is usually 101"/102" on all of them. On a 7' wide you will have NO fender boxes inside the trailer, smooth walls inside because the entire fender is on the outside. On a 7 1/2' wide you will have approx 3" of fender box inside on each side, the rest is on the outside, and on a 8 1/2' wide you will have most of the fender box inside, very little outside as the walls of the trailer are almost just as wide as the wheels/tires.
So you gain some space with the wider trailer BUT then you also have the fender boxes to maneuver around with the sleds.
We have an all aluminum 7 x 25' ( 20 + 5 ) inline and I am very happy with it. We usually only haul two sleds in it, and I back them in from the rear keeping them right inline with each other nose to tail and drive them out the rear. Our 137 and 129 take up just about all of the 20' of straight box to stay nose to tail, which is why I got the 20+5.
I do this because we also use it for road racing motorcycles in the summer and I have some cabs/shelves up in front so I never use the front ramp door. Due to the low floor and slight ramp angle it's pretty easy to back them in from the rear. Like others have mentioned, these trailers are mostly designed/balanced to have the sleds facing the rear, and I did pull it once with the sleds facing forward and it seems to tow nicer with them facing the rear.
Just some more food for thought for ya...............
18' + 5' is definitely sufficient for hauling 3 sleds if staggering them. I think what rich_jelinek was saying is he parks his one directly behind the other in a perfect line. Most people don't do that.
As stated earlier, the minimum I would go if buying a 7' wide inline is 22' total length including the V. Mine is 23' and works great for 3 sleds (129, 144 & 121 sleds). I think some manufacturers make a 22' long one which also would work. Don't go less than that though if consistently hauling 3 sleds and wanting to park them all in the same direction.
Being that I've never owned an enclosed trailer nor saw sleds inside of a "7' inline trailer", I can only imagine them being "nose to tail". I would prefer to set up the ski runners and track mats in this manner.
So it sounds as if your 129 and 137 don't leave much room for a 3rd sled in a 20+5? Dealers and some here say an 18 + 5 is sufficient for 3 sleds. Maybe I'm not reading something right then.
I have a Legend 19x4 enclosed inline and could not be happier. I pull two sleds straight in and back them out. I found if they are facing back the tongue weight is too light. Both sleds are 4 strokes with 141 & 137 tracks. I can park them with the skis of the one around the tail of the other sled or swing the rear out and pull the one in a few more feet. Could 3 fit in there, sure facing the rear but one most definitely needs to be a short track.
I choose a inline since the tires are easily accessible if you have a blowout and a larger tire is spinning allot less than a small tire. I bet someone here can do the math on a 15" tire spinning at 70mph vs a 12" is ---?mph
Why does the ramp flap look so goofy on that trailer?
The neo has an outside pivot that the ramp apron is attached with....no piano hinge.
Best set up in the industry, along with their single point SS ramp latch.
Thanks for the picture Rich! Much appreciated! I can deal with staggering the three sleds as was suggested here. Right now 2 of my 3 sleds are nose heavy Yamaha 4s' so I'll have to keep the tongue weight thing in mind.
This reply probably don't matter by now anymore, but my 2 cents worth is, it comes down to what your pulling the trailer with. If you have a half ton vehicle, go with the inline (7') if you have a 3/4 or 1ton diesel it will pull either style trailer no problem, and be able to see around the majority of either also. I had a 1/2 ton 4x4 and it had everything to do to hold 60 with a 8.5x 26' steel frame enclosed. I then bought a 3/4 diesel and the trailer was a toy behind it, so I upgraded to a 40' all aluminum enclosed. I can see far enough back to where I am comfortable, and the only time I know its back there is if I have a heavy cross wind. If its fuel mileage you are concerned about, I can average 12 pulling mine at 70mph, a fellow club member gets 10 puling his inline 4 place with his 1/2 ton. The only thing I have noticed is when loading a inline you have to position the sleds in certain spots/angles to fit them all. (lots of manual labor) With a8.5 wide trailer, drive in and stop done. Only time you may need to touch them is unloading if the "V" of the trailer is 4' and you have to kick the *** over to drive out. If you go with a 5' "V" they SHOULD be able to make the turn without manual repositioning. I had my trailer custom built with double doors in the "V" so I can drive left sleds out the right, and right sleds out the left. Again just my two cents, enjoy your purchase which ever way you go.
