In the black hills there will be well over 2ft maybe even 3If you have the itch, Rapid City, SD only about 8 hours drive west of the Twin Cities.
* MAIN HAZARD...SNOWFALL AMOUNTS OF 7 TO 15 INCHES ARE EXPECTED
WITH LOCALLY HIGHER AMOUNTS POSSIBLE. VERY STRONG NORTHERLY
WINDS OF 35 TO 55 MPH WITH GUSTS TO AROUND 70 MPH WILL COMBINE
WITH THE SNOW TO BRING NEAR ZERO VISIBILITIES.
The NWS began naming the winter storms due to the impacts that can occur should the storms develop. All in the name of preparedness for the public. In light of the fact that this storm is developing in early October & the amount of snowfall expected is in the double digits plus, I think it is a good idea as it gives the public time to react & prepare.-Mezz
The Weather Channel said:The Weather Channel, for the second year, will name winter storms. The naming system "was a terrific success" last winter, said Bryan Norcross, meteorologist at The Weather Channel.
The weather channel started naming winter storms to boost their ratings. Along with this they started having very little weather on the TV and changed to mainly "reality" shows that could possible have something to do with weather. ha
Right you are, I did mean to put in TWC, just responded too quickly. FYI, TWC originally gathered it's national region forecasts from NOAA & it's local forecasts from the NWS. I am not too sure the whole reason for the naming if the storms entirely surrounded around it being declared a "blizzard", I believe it was the timing of the storm (Month) & the amount of snowfall expected, nonetheless, the naming of the storms was not developed to boost ratings of TWC.-MezzIt is the Weather Channel, not the NWS that started naming the winter storms. When you have a memorable storm you can then say the name years later and people know what storm it was.
