I was wondering instead of taking the air box off which is a pain. I was wondering if I can used the carb vent line and put a t on it and spray the fogging oil while it is running if that just as good to?
2006polaris supersport and 2001 skidoo 600 formula
you'll know if it worked if the sled dies on you. spray it in there, brap the throttle while your doing it a few times and if it's hard to keep running or it dies while idling you know you got the oil where it needed to go.
