Catalac,
Do you have grip heaters? If so, you might try taking a can of the expanding foam and filling the inside of your handlebar ends.
I took a drill bit the size of the foam tube and opened up the rubber end cap so the tube would fit inside. Then I filled the tube with the foam and put a piece of duct tape over the end of the grip to keep the foam from oozing out. Then left it set 24hrs to set up.
What this does is fill the hollow steel tube and insulates the steel. This aids the grip heaters in that they dont have to heat the dead air space. Its easy to do and only take a few minutes.
On a cold day I would have to run mine on high most of the time, now low is too much some times.
