I think you are forgetting something, track alignment. I have always just eyeballed the tension or used the two finger rule should be able to get 2 fingers in where the track sag is the greatest with no weight on it.  But it sounds like your passed this now.
Here is what you need to do once you get the sled running.
First you will need to check see track is centered.
With rear of vehicle supported off the ground, start
engine and allow the track to rotate slowly.
(Once I know its not really far off I give it some gas too.)
Check that the track is well centered; equal distance
on both sides between edges of track
guides and slider shoes (hyfax).
To adjust, loosen the rear idler wheel retaining
screws then loosen or tighten the adjuster bolts
located on the inner side of the rear idler wheels. Remember a little adjustment goes a long way. Also remember adjusting the right side will push the track to the left and vice-versa.
Also I'm sure you have seen this link on here before:
http://chadt.us/manuals/index.php?option=com_docman&task=cat_view&gid=36&Itemid=57
he does not have your sled but the procedure for everything you are doing will be the same. If the Poo book does not cover it I know the Doo book does.
