Sorry to thread Jack, but strokeit what did you do to your front suspension to raise it so much? And did you have to extend your cables for that riser? One of the best looking zrs Ive ever seen, nice sled.
If i go to a 1.75 or 2 inch with scratchers will i be okay, i trail ride the lower alot and have hear it is a bad combo? thank you for the info!
It depends how much trail riding you are talking about. If 80-90% then I would go 1 1/2" track or even 1 1/4". 1 3/4" or larger will give you vibration on hard pack. I don't think you would really like it in the long run. I have 1 1/2" X 144" now (it was on the sled when I got it) and I really like it. But when I change it I will go back to 1 1/4" or less. I just don't get off trail enough to need the bigger lug. Plus with 1 1/2" I can't pick it.
50 /50 will turn in to 80 /20 then you will be saying what is the point in trail ridding and you will be 95/ 5 and you will be pissed you wasted your time with a 1.5 and be looking for a 153 2.25 and saying well for the 1 time a yr I ride with the wife on the trail It will work.at least that is how it has worked out for most guys I know
