FInally got my 99 indy 500 back together-again. i got the new driveshaft bearing on and before i tore it apart to put the bearing on, i had some bogging issues. with around 6500 miles i put on new spark plug boots. then at around 8000, it was running boggy and on 1. so i looked and the boots were eating the spark plug tips, the spark plug tips would get all wore out. so i replaced the boots again. o ya, and i had to put a new bolt on my cdi since one of them fell off. so after these new boots and new plugs, i can get it to run. i can get it up to speed and it feels like it's running on both but when i let off the gas, it gets boggy again but still is running on both cylinders. then all of a sudden when i let it idle, it runs on 1 and the rpm's decrease and then the sled shuts off.
any help would be appreciated. the carbs were cleaned and synchronized this fall. and both plugs are cocoa brown. i've put quite a few sets of plugs in it to see if it makes a difference.
could i have bad carb boots? they were all cracking. i took of the airbox to change the driveshaft bearing and jackshaft bearing so could i have tugged on the boots too much and put a good rip in them and that could be causing this? it kind of feels like bad intake.
