firefighter1
Riding my 2011 renegade bc 800 etec on friday for the first time since the piston update last spring and about 70 miles into the ride the sled goes into limp mode. The symptoms were check engine light, and also when you would restart the sled it would idle fine but no lights would come on not even the dash lights. So I happen to be right by the mosquito so we went and ate. After that it seems to start but with no lights until you hit the throttle and built up rpms, otherwise with you let it idle for 30 seconds the idle would increase on its own and lights would come on and the dash would go thru it's sequence. Ended up towing it to Houghton power sports, Saturday he started it and it sounded great and then he drove it around the build and I could hear the 4 beep sequence and he said when he got around back it just died. They hooked it up to buds and the computer said low voltage code p1562 and high voltage p1563. They tested stator and came back good, they tested the capacitor which tested bad. Has anyone expirence this before and had to replace a capacitor? Just wondering, I have heard of stators being replaced.
