got an 07 polaris iq 600 ho carb that has a top end of about 80. i am out of ideas with this thing and at this point will be making an insurance claim on it next year.
JK... anyway. the top rpm is 7900, it is stock gearing. replaced primary and secondary springs. rolers and weights are good, maybe need lighter weights to get rpm up but sled should still be faster then 80, it would do 103 when she was new. i have changed some carburation but even at stock the missing top end persist. what i have now is 410 mains with 40 starter jets, stock is 420 and 50's. does have a low end bog if i go to wide open throttle from stop. if i feather it goes just fine.
I was cleaning the ves valves and the cap that holds the guillotine striped out and the guillotine was just sitting down and never moving and actually had a chunk break off and fly into exhaust which i was able to retrieve. ordered new parts and thought for sure that would solve my problems but no, it did not. i am loosing my mind with this thing.
how do i test the exhaust valve solenoid? it ohms out at 13.9 and should be 15 so that should be okay. Should it be open or closed with the sled running. I can not blow through it with the sled not running. i realize it does close or shut till 6800rpm or so.
belt has 700 miles on it but compared to a new one i got and seems in good shape. same size and everything.
hope you guys have some ideas, i am out and getting tired of this beast.
