Specifications:
Battery type: Removable/Rechargeable Lithium Ion (about 2 hrs recording time)
Size: 3” length x 1.5” width x 2” height, weighs 4 ozs.
Video: 1280 x 720 pixels in HD mode
Frame rate: 30 fps in HD/ 60 fps in SD
Memory: Record to included 2MB microSD flash card
Lens: 1/4” 4g (135° viewing angle)
LIMITED WARRANTY
Twenty20, Inc. warrants this product to be free from defects in materials and workmanshipfor 180 days from purchase.
Subject to the terms of the TWENTY20, INC. LIMITED WARRANTY, available on
www.vholdr.com.
Whats New??
Better Video and Bigger Lens
ContourHD helmet camera has two video settings instead of just one. High Definition records video at 30 frames per second while the High Action SD setting records helmet cam video at 60 frames per second. In HD the new wide angle lens (135 degrees) allows you to capture the entire scene.
Faster
Boot-up is now UNDER 5 SEC and download speeds have been cut in half. Transferring gigabytes of HD Helmet Cam videos only takes a few minutes.
More Memory
ContourHD is compatible with up to 16GB MicroSD memory cards. Now you can record up to 8 hours of HD or 16 hours of SD helmet camera video.
New Microphone
We have included a new microphone to reduce the wind noise and bring out the rich sounds of the action. Our wearable camcorder is better tuned for sounds of the action.
Share HD
The Easy Edit software and VholdR.com have been given an HD and widescreen face lift. Upgrading ContourHD to the H.264 video codec also makes your videos more edit friendly.
