A little snooping
I did a little Non Internet research last night/this morning. There are two confirmed reasons why the Etek's can have problems. 1st- Over Rev'ing. This is not only on the top end (8000 rpm is what they like) but mid range shift. 2nd- Oil. Use what they say or go home. Same as Polaris. Same as Cat. Same as Yamaha. Every oil is different and there are reasons for that. Some is the $ and a some are for specific needs of a motor. I hear people bitching that a 2 stroke has to use more oil than they are (Etek) and that low oil consumption will prematurely wear out a motor. Well, times have changed and synthetic oil has also. Synthetic by definition; chemically produced substance or material: a substance or material produced by chemical processes and not occurring naturally. They make that oil have exactly what that motor needs and nothing more. Why, because that is waste and hinders efficiency. I guess I have run every type of sled imaginable and I have seldom had any problems with a vacuum cleaner(stock sled). I have wrecked alot of motors in may day and I will take the blame. Maybe others should also!
