Well it had to happen to me! My son's '03 ProX 600 (no longer have) grenaded the chain and chain case a few years back at the fault of a broken lower gear bolt. After all properly repaired it ran fine. The next year curiosity got the best of me so I pulled the cover and sure enough the head of the bolt was broken again!! At least I caught it this time. I installed new bolt, loctite, torqued properly and it was ok the rest of the year. This year I bought an '03 700 Classic Touring with 2k miles, like new. Within 250 miles and of course the first day of a 6 day trip in Northern Wis, broken bolt and grenaded chain case again!! At -20 degrees, I patched up the chain case with JB weld and RTV sealant and rode 3 more days before it began to bleed gear lube badly enough to just park it. Well this time I'm a little smarter. I'm gonna drill and tap it to 3/8" bolt and hopefully do away with my achilles heel. Well my son has an '05 700 RMK now and I thought all is good until I looked up part numbers and found that his sled uses the same little crappy 5/16" bolt that is so well known for letting go. I guess I will be proactive and drill and tap that one to 3/8" too before it lets go! On the flip side I had an "02 600 xcsp that used the same bolt and no issues in 6,000+ miles.
Question: I just bought an '06 Fusion and the lower gear bolt in that is a different part number, anyone know if it is larger or just a different number?
Recommendation: Check your Po-Po's part number for the lower gear bolt. If it's 7517979 I'd be checkin it out or your just playing Russian Roulette!
