x2 on the 1.0 paj and 410 mains, 400 seems a little too lean, but 55 pilot jets? Thats WAY too rich... Doesn't your sled load up?
No it doesn't load up unless you let it set and idle to long, the 1.0 paj helps to lean out the 55 pilots.
Fastmod62-Did you change the needle position with your set up?
Motor_slut-Are you suggesting leaving the jet settings stock and just play with the fuel screws?
Is there an easy way to even get at the carbs in these sleds? I have an 06 Fusion 600 and it locks like a total PITA to get at them to re-jet. My engine was rebuilt about 1,000 miles ago and the mechanic changed the jetting for the break-in period. I'm going to have him re-jet it back to factory once I get up there this year (President's day weekend, assuming there is snow). With all the posts above, I'm wondering how I should ask him to jet it, if not stock. I was considering going with the stock jetting
and then adding the Holtz Engineering Attack, so I don't have to deal with jetting anymore. Just another idea.
I called and talked to Nate at JS Powersports as suggested here. He was very helpful and knowledgeable. I ordered from him new Main Jets, Pilot Jets, and Pilot air Jets. Now, My question is where can I find a "how-to" for replacing these? Is this something a novice like me can do? Thanks for any info.
Good information...is the stock main jet a 420?
My biggest concern in taking this apart is getting it all back together. Those carbs are tight and I've heard multiple times the airbox is a PITA to put back on.
Snowdance and tgun - is this set up for you guys both for riding in the midwest?
