I looked up my setup and I used .60 pilots. .9 air and 400 mains. This was the setup I have run without issues for a while now. Ran to10 below or more. Just have to fiddle with the fuel screw a bit. If you have a hesitation just off throttle try the choke at the first position. If that helps off throttle it is too lean. Turn out the fuel screws a 1/8 or 1/4 turn and try again. If you have a bog that gets worse with the choke its a bit rich off idle so turn back in. I know I tconfirmed this with Willie over at HCS via email...he ran this in many Fusions in Quebec where his shop is. I also have a n article from 2006 from a race guy that tested and perfected it to the same setup. Hope it helps but i can tell you it's worth it. Key: check piston wash and plug color. That will show you the way. Also..if you have not replaced the carb boots do it when you pull the carb rack. Original ones are junk. -chiefcheese
THanks. I'll keep these tips in mind when we get the sleds out in a couple weeks. We did check the carb boots when we had it apart. The ones on my Fusion have been replaced once before. The ones on the 07 are stock.
