I have a 06 900 rmk, and my ski is broken i found a great deal on a set of 2011 rmk gripper skis. Will my mounts work in the 2011 skis? i havent been able to really find imformation else where so i figured i would try here.
if I can fit grippers on my cat u should make them work for your poo. as long as the ski bolt is the same thickness washers will take up the slack and rubber snubbers can be cut if need be. just look up part numbers for ski bolt that should be all u need to figure it out
