Is this really possible that by idling for to long it you will create a hole in your belly pan? This is what Polaris is telling me. If so what is the maximum amount of idle time you can have before this happens? Ridiculous!!!!
I let my sled idle 10 minutes sometimes. Never had a problem. I don't touch the throttle until the sled is fully warmed up.
Mine would load up and die long before I could clock 10 minutes of idle time.
Unfortunately, that is what happens if you let the sled run/idle too long setting in snow and there isn't enough of an open area for the exhaust to exit.
Had the same thing happen on my '10 Shift, would let it idle until the temp gauge showed like 70-80 before taking off.
My dealer nor Polaris wouldn't warranty it.
If you can't get it taken care of under warranty, just looking at an online parts source, all new parts to replace that plastic section (fender as its called) is around $180, not including labor), I'd look at fabricating a heat shield for that area-maybe one on the inside and one on the bottom to cover the hole.
Even if you would replace the parts, what is going to keep it from happening again?
