if storing where mice might like to move in, a few moth balls under the hood should keep them at bay.
that is a old myth.I had a sled that they took the moth balls out of the box and put their nest in the box.bounce is a bunch of bs also they had pieces of shredded bounce in the same box
Might be good to top off the tank. I used to leave them where they are and add stabilizer but after my 1 sled rotted the tank line this year I'm going back to fill em, stabilize them, dump in car at beginning of next season & re-fill with fresh. Less evaporation with a full tank also.
Boats are shrink wrapped for storage. Is it wise to shrink wrap a sled? My storage area has had a history with mice.
Fill up the tank with good quality premium gas, gas will loose octance level with age, pull the plugs and spray cylinders with fogging oil, pull cord a couple times, to help coat cylinder walls, reinstall plugs, shut the fuel off,
I have done it this way for 20 years, never had a problem,
come december, turn fuel on, tighten plugs up, full choke, starts on 2nd or 3rd pull every time,
I will take it somewhat easy untill I burn through the old gas, then filler up with premium.
Sea Foam. Fog Engine. And LOTS OF OTHER STUFF. A kid gets a lil bored over the summer...
