Either pressure tank blatter is shot or pipes from well leak losing pressure causing pump to recycle. Both common problems that need to be corrected as both only get worse systematic to more costly problems. Looks to me like your are going to spend some money on repairs.Another question. My water pump in basement runs for 20 seconds, around every 20 minutes. No water is being used in house for last few hours. Is this normal you think??
No noises from any toilets. House is 70 degrees.
i had this problem last yearEither pressure tank blatter is shot or pipes from well leak losing pressure causing pump to recycle. Both common problems that need to be corrected as both only get worse systematic to more costly problems. Looks to me like your are going to spend some money on repairs.
Sometimes a piece of those blue cakes can get under the seal of the rubber flap and it doesn’t close all the way?The silver valve to toilet is all the way to the left. Here is pic of fill tank. The blue spot is a toilet cleaner pill that I put in about 6 weeks ago.
Yes the stopper doesn’t seat it will keep calling for water until the proper level is satisfied. It’s really simple mechanics. If the blue cleaner caused the stopper not to seat that could have caused the problem especially if you are holding the lever down the water comes in quite fast causes a current when drained moves the blue disk. Seems I had the same problem with those disks stopped using them more problems than they are worth especially when the family used the toilet.Sounds good. I was gone the whole day and just got back and checked the water pump. No dampness or dripping at all, so it did not keep going off while I was away today.
If the flapper was bad, wouldn't the water from the tank be lower and drip into the toilet bowl while I am away? The water level in tank is not changing while I am away. I think problem is fill valve or floater.
