Hard to see what kind of rivet you need. There are rivets called stavex rivets which are heavy duty, I just bolted things together with torx button head ss bolts & nylock nuts when I had to replace those. OR you can pull up the sled / tunnel diagram on an on-line web site " cycle parts nation " for example and it will show you generally what you need.
