Scottikings new sled
Firecatguy
yep thats the one...
also
walking around sunday at Haydays I seen switch covers for the kill swithch and for the heater controls I will post some pics later today.
this will keep you fromn shutting the sled off in a steep pull or in deep pow as i did that last year and had the sled roll down the hill {nailed me on the way down}
Firecatguy
here ya go cuzz.
scottiking
Nice! I like the that billet guage cage and the kill switch cover- I can see hitting that kill switch!
anyone know if you can add a 2 inch riser or 4 with out changing cables?
Scottiking OUT
i just added a 3 inch and i could've gone 4 but there wasn't a 4 in. at the wausau swap meet that was only $5
cuzzinolaf
I have a five inch riser on my 2008. You're good with a four if you reroute stuff. I had the same riser I have now on the 2007 M6 I traded in.
Firecatguy
scotty,
if you look up by my stering post you will see the siver bag!!!That is for your googles,when the hood is closed you have a warm pair of goggles..
when it comes to a riser--you can get the parts for the upgrade to 09m cat with riser..its around 200$ but worth it...
sabercat
Rusty--> What did you do to get your belt off? I can't get my secondary clutch to open. Not sure if I'm doing it right.
Firecatguy
scottiking,
look just below this thread as someone brought it to the top...
sabercat,
take the bolt out, pull the silver thing out of the middle---turn around and then put the bolt right back in this will then open the clutch..
you can also just pull the clutch off with the belt still on you just cant get it back on that way...
sabercat
Thanks Rusty! I just tried it, worked perfectly. I was trying to get it open like a firecat, where you remove the shims..that didn't work. When I changed the weights last year i had to remove the whole clutch, thats no fun when you know there is a right way!
sabercat
scottiking: If its true that 07, 08, 09 are the same then you need this part #-->5639-153 KIT,ADJ STEERING POST '09 M STD
Thats what it says on the Arctic Cat box. That steering post is sweet!
scottiking
Anyone put a "y" pipe and can on one of these?
I heard it wakes up the throttle responce!
What brand is best? SLP,straightline performance? D&D??
Thanks Scottiking
