I just pulled out my 2000 sea doo jet ski and noticed it has a couple of hicups/pops at lower rpms then runs clean all the way up to 7200 rpm. any thoughts.
So I sould be checking a few things, how and where is the exhaust regulator, and do I simply install a new one or clean the old one. I will clean the power valves as well, now where is the filter by the carbs, I did find a filter by the front of the sea doo by taking out the front storage container, anything else i should do. do you guys have any pics of these items to share.
thanks
Bobbo,
I will check for the leaking water regulator, should the red adjuster nut be all the way in or what setting if any, I will leave it alone if no dripping occures. I assume like sleds the power valve gaskets will need to be replaced when i tear them off. do you have a good source for sea doo parts?
John
