michaeladams
without taking the suspension out how can you tell if you need to rebuild shocks or not? 03 polaris classic 500, 8000 miles.didn't seem to ride bad when put away.i think they are original fox shocks all the way around sled.
Definatly get it done. If you push down on it and it doesn't come up really fast, then it needs to be rebuilt.
???? I like rebound in my shocks. Riding a pogo stick suspension aint no fun.
With 8000 I would get them done. Do you bottom out alot? You can pick up the rear and see how much it sags when you let go. I have always moved it up and down with one hand and if I moves too easy then it's time. I would remove and give your suspension a good look over as well.
Indy, you want them to compress slow, and you want them to rebound slow. If it rebounds fast, that usually means the shock is toast. You do not want it to come back to fast. To fast means less control.
Well its pretty obvious something was wrong with it, but it aint from not having a charge anymore. Gas charge shocks come back to full extend, oil charge shocks dont. There is different valve stacks to change the rate of compression and rebound, but if it took 2 mins, either somebody didnt know what their doing when they built it, or its broke.
