skidoodoug
Is it possible to clean/rebuild a clutch without removing it from the crank? Can I just split the 2 halves?
Doo clutches can be split on the shaft. There are arrows and marks to line up when putting it back together. Not rocket science. Once you get the sheave off, then the inside of the sheave slides out, but nice and easy. I assume you won't have the tool to hold the buttons in so try to do one at a time so not to lose and buttons, o rings, or springs. They can be assembled one at a time when going back together, just don't forget to line up marks every step of the re-installation. Once you get it apart, you can check all the rollers and weights and clean as needed.
All that is left on the engine is the inner sheave and shaft. You take all the inner workings of the clutch off either way, but it does make it nice not to have to take the sheave off the crank when repairs are needed away from home. It would not be easier, nor would it be a whole lot harder by using a puller and taking everything off, but one less step and one less tool needed. Makes it nice when you don't have a puller, repairs can still be made!
