I was told you should hand tighten the chain in the chain case by turning the rod that sticks out of the chain case behind the muffler, I know
This is a bad description but for those of you that have done it I know you know what I am talking about. Anyway, I was told to loosen the bolt
On top then hand turn the bottom of the rod till tight then tighten the bolt on top again, but when I lossen that top bolt it all turns as one unit
So there is no way of tightening or turning the bottom because it does not thred through the top bolt, in other words when you loosen the top bolt
And then turn the bottom by hand it just tightens the top bolt back up snug on the frame, so all I am doing is loosening and tightening the bolt and
Not actually tightening the chain. Any ideas? Or what am I missing? Any help greatly appreciated.
