firefighter1
I have a 2012 Polaris Rush 600 for my son. It has electric start and seems to not want to start on a cold engine but will start after the engine has been running. Some of the things I have done so far, new battery last season and kept on tender all summer. I did remove it and take it in and load tested good. The battery reads on multimeter 12.8 Vdc and when running 14.4 yesterday. I also put in a new solenoid as they are cheap, during the summer I replaced the bendix as it was bad. I also ended up getting a new flex shaft as it was welded to the bendix. Starter was removed and bench tested good. What it does sometimes is the bendix engages the ring gear but does seem to spin it fast enough to start the sled. I stopped and talked to my local dealer yesterday and he suggested replacing the cables that run from the battery to solenoid and then from solenoid to the starter. He said Polaris used fairly small gage wire from the factory and it doesn’t transfer the current as efficiently. He said they did this a fair amount on Pro-ride chassis over the years to help with cold weather stating. Has anyone ever done this and do you think it helped? I have no volt loss going from the battery to the solenoid, I haven’t tested from the solenoid to starter yet but I will. Dealer said just pull the wire out which is very accessible and have a auto parts store make one with the thickest gage wire that will still fit inside the plastic sleeve the wire goes in. Sorry for the long post. I will say this is my first Polaris I have owned and they have a ways to go on their starter systems.
