switching oil.....
Firecatguy
so i have decided to make the switch to Mystic sea and snow......The question i have is cat oil semi-synthetic and is S&S full? will there be any issue if I just run the cat oil down to a low amount then fill with sea and snow???
russholio
S&S is semi-synthetic. Should be no issue mixing it with your current oil. But if you want peace of mind, run yours down as low as safely possible (i.e., not so low that you get air bubbles in your oil line), then top off with S&S.
scottd
Just switch, after a tank or two of gas when there is 1 quart plus of room just start pouring in the other. I would not constantly be mixing oils and just dumping anything in there but you should be just fine making a hard change. I have done the same with both of my sleds, just wait until a quart plus will fit and then start using the new.
salmonbum
As above, no problem letting you oil tank get low and the just fill up. What I did when I switched from doo Semi-syn was to use an oil pump I had laying around and sucked out the doo oil from the tankin my XP and put it in my REV. So now my XP had a full tank of S&S and the the REV was full of Doo oil. I carry a quart of extra oil with me, so once the REV was a quart low I put the extra doo quart in that to burn it up (got rid of all DOO oil). I filled the empty quart with S&S and ran the REV until the oil was very low. Then I dumped in the S&S. Once I got back to the truck I then topped off with S&S from the gallon jugs.
Did you have to bring up that your switching to sea and snow? :)
mjkaliszak
Agreed, I even change the rentals over to SS for the dealerships, brand new sleds everyyear .3 miles on them .... ( LOL ) Then we procede to bust them up, not so funny @ check in time.
woodi
If your worried about oil in tank u can buy a turkey baster & suck it out.That also works 4 putting in chain case oil through dip stick pipe.
well I filled a sled that was 1/3 full of cat oil with ss last week and then blew the dimond drive 2 related no but it happend prob would have been all good if I used amsoil I guess
1050 no noise just rolled to a stop and it would not move. got to move after a bunch of swearing revese forward shaking secondary then a nice ez 30mph no stops home.planitary was gone 3 bad cogs 2 good.just orderd a bdx light DD drive and light driver today so I should have no more issues .box is getting reflashed to 09 and orderd a reverse notched helix and been reading up on rewiring ecu on back country rebels so I will have 09up motor reverse and no more pos reverse dd
sabercat
Rumormill
I heard that S&S doesn't burn clean and it comes out your tailpipe and coats your track, then it lights on fire...
hahahha
-Fluffy-
