had a few moments to work on the truck today and pulled the radiator. Laid it flat on bench and filled it fast and opposite side filled quickly, no particles, contaminates of any kind. Filled it many times shaking it up and seems as though it was and is clean especially when you see haw fast the water transfers from one side to the other, it's not clogged or restricted. I did order the head gasket kit yesterday from Napa and will be in tomorrow. Probably pull it apart tonight if i can get motivated. I could not have gone about it any worse than I did. One symptom I have seen while working on it is the water level slowly raises and seeps out of the rad cap when open and engine running. I kinda though maybe as the water heated it was somewhat normal but if that cap isn't on and system isn't pressurized it should circulate. So here is my theory, I am getting compression from a small leak in the head gasket, leaking into water port, slowly increasing pressure in cooling system causing the overflow, and creating air in the system causing a lock in circulation. Just my theory in my limited understanding. Also, on this system, a thermostat cannot be put in upside down because there is a small flange that prevents the mounting of the stat upside down.
Next time, I will be able to apply this experience but now I am friggin discouraged but the end is near and all should be fine. At least I don't have to worry about the stat, rad, water pump, intake gasket or head gasket for a while.
I mean think about it, the very first thing I did was pressurize the system and I did see the pressure raise. I guess I was hoping for a drop but the book did refer to increase and that being a head gasket, "what were you thinking Lenny ya stooge."
