Like I said before, I'm not disagreeing with him, but I DO NOT think this is an issue either, unless you are hard on the throttle right away.
Furthermore, for the amount of gas used at idle, the amount of oil doesn't need to be much. If the 5 injection points of oil in the bottom case each inject 1 (one) drop of oil each every other second, which seems like a reasonable amount, that should be plenty of oil for the amount of gas being used. And how is the minuscule amount of gas, which by the way is atomized, going to wash the oil away.
I can however believe the the reason why the wrist pin bearing is always blue is because of low oil usage at idle or very low engine speeds. Every wonder why every single wrist pin bearing is blued from heat???
Again, I am not disagreeing, and he's more than likely right, but IMO I think the problem is more about letting it warm up at idle then immediately hammering WOT.
I'm not adding oil to my gas unless Im breaking in new Pistons. And I probably add less oil breaking them in, then most people.
