Can I play too
nope....just a sledder that has over 100,000 miles on sleds of all brands and has encountered more break downs than you have shiite yellow....heres a few of my sleds...lets see your ARMCHAIR RIDER....i also tried SNOW-X racing...lets see our stuff and knowledge bigshot
'09 Z1 Turbo LXR LE 5968 miles still own
'00 1000 triple Cat 23,500 miles
'99 800 triple Cat 16,400 miles
'99 800 triple Doo 1740 Hated that sled
'98 1000 mod triple cat 1350 still own
'96 900 triple Cat 11,400 miles
'96 600 triple Cat 8700 miles
'93 900 triple Cat 6800 miles
'92 750 4 cylinder yamadog 720 miles liked trees at 65 mph (8 days intensive care)
'80 440 LC SRX 1750 KM biggest POS I ever owned 4 tear downs
'79 440 LC SRX 2500 KM
'79 440 LC SRX drag sled 1830 KM stolen off my trailer Complete engine modify
'79 440 Exciter 6820 KM
'78 500 fa El tigre
NEVER HAD a problem starting in fall
With exception of the POS '80 SRX, NEVER HAD A breakdown
Never Had to work on a SUSUKI engine, notice the high miles, never did a ring job.
Back to the topic:
I think you are SOL Several things you could have done after the shop to cause the problem.
I treat with seafoam and fuel sabilizer, run engine until hot (feel heatexchangers). On two strokes, put oil in spark plug hole, slowly turn over a few times, put more oil in. put plugs in and turn over again. Drain treated high octane fuel out of tanks and put into '87 GN.
I disagree with the heat and humidity aspect on a carb sled (more so heat). The carb is not jetted to run in warm temps and will foul the plugs MUCH quicker! That is why my 2 smokes I never started until late fall when cold outside.
On the last to 2 stokes, I changed the plugs once... at 10,000 plus miles. Only because the sleds had 10,000 plus miles. With the exception of running 7 gallons of diesel in the 800 triple (never let your friend fuel the sleds), never fouled a plug in a Susuki. (by the way, I did burn the diesel through the sled, had to run with the choke on)
Check my stats, I might know a little something. I also solved two problems with the '09 Turbo's that mine was in the shop 4 times to get resolved under warranty. I'm sure my royalty checks will be in the mail soon from Cat. (yea right)
LET IT SNOW
