snow_monkey
Harbor freight spring puller $4-6 dollars t-handle 6-7 inches long love it.
If you have a new e-tech you need a long one to reach the back spring, bloody knuckles without tool!!!
Three time-saving tools. These Python™ pliers feature: 16" overall Python™ length for true long reach access. Three different head sizes: 5/16", 1/2" and 3/4" designed to remove and replace spark plug boots, hoses, PvC, tubing, lifters and any round object without having to disassemble obstructions. Full polish face and shank-coated with a special clear acrylic to provide life-long resistance to corrosion. Contains: Large Gripper 3/4".
Medium Gripper 1/2".
Small Gripper 5/16".
These do it all. Push/Pull- Long reach. You have to buy the better quality pliers. The Harbor Freight/Northern tool China made will not hold together while pulling.
Country Of Origin China
I did the same to a big ol (and cheap) long flat bladed screw driver. Took it to my bench grinder made a small v notch in the tip for push applications. Then I made a hook cut into the edge for the pull applications.i cut a notch in a screwdriver it works great
Any of the ones listed about 3/4 of the way down on the page. Your knuckles will thank you.
http://www.hiperf.com/ATV/acatalog/Shop_Equipment___Tools.html
What do you use to remove exhaust springs?
A buddy has a long t handle tool with some slots in it that seems to work pretty well. Is there something better than this? Perhaps some kind of pliers?
