I like my legend, but as others said, most are not without their problems. A lot to do with the environment that we tow them in! I don't have any direct experience with other manufacturers. Went with legend due to axle placement further back for better handling. When looking at trailers, consider some of these things: Where is the emergency brake battery located, accessible for charging/maintenance, or stuck up underneath trailer hidden by frame rail. That's not great for accessibility as well as the corrosion issues. Also look at where the wiring/junction box is, the transition from the molded 7-way jacketed wire to all of the individual wires going to various lights. One brand I looked at, this junction box was nothing more than a galvanized steel construction box, residential style, underneath the trailer tucked up by the frame rails, right next to the brake battery. Not the greatest location, would be a corrosion nightmare in a couple years, especially considering a lot of manufacturers use basic non-shrink seal splice connectors. I've seen regular wire nuts used with no tape on some. A purpose built trailer wiring junction box, located inside the trailer is a step in the right direction. These were things that steered me to legend as well. This was 6 years ago, so I'm not sure if any things have changed for the good or bad with manufacturers. I looked at Royal Cargo trailers back then, and was turned off by the lower quality of the wiring. Maybe they've changed.
