Do some engines actually require premium for the compression, or just because 91 usually doesn't have ethanol? My girlfriends naturally aspirated Acura actually has higher compression so it will wreck the car if not used. My SRX says premium, which I run now, but I have also run it with regular 87 in the past no problems. I don't really rail on the thing so its pretty much babied despite all the power it has.
I think most sleds do not require 91, but most have a setting to run on 91 or they just run better. Less than 91 has more potential for knock and the sled will retard ignition and make less power.
I didn't mean to start the octane argument thread. I just wanted to know if they say run premium because the engines actually have a specific compression, or if it is because 91 is sometimes deemed recreation gas with no ethanol.
87 in the turbo sleds is just not a good idea....it may live for a short while but the possibility of engine damage is always lurking...there's a reason the mfr "requires" 91, why challenge that?Do some engines actually require premium for the compression, or just because 91 usually doesn't have ethanol? My girlfriends naturally aspirated Acura actually has higher compression so it will wreck the car if not used. My SRX says premium, which I run now, but I have also run it with regular 87 in the past no problems. I don't really rail on the thing so its pretty much babied despite all the power it has.
I have to disagree "OCTANE" is a fuels resistance to spontaneously combust, the higher the octane the less likely it is to spontaneously combust (or ignite before the spark ignition takes place) Not all sleds require it, the sleds that do are generally a higher compression engine. the higher the compression the more likely for fuel to ignite before ignition thus the death rattle. The pinging you hear is fuel igniting before combustion/ignition takes place. putting high octane fuel in an engine that does not require it does nothing for performance and if you think it does you are just convincing yourself that the extra pennies you just spent are somehow doing so. Now.... if you put low grade/octane fuel in an engine that does require higher octane depending on conditions you can destroy the engine (burn through the dome of the piston or erode or burn the exhaust side of the piston skirt, this is usually the result of that death rattle you hear when you put the wrong gas in your sled or pumped something that isn't what it said it was and this is why (if your sled requires premium) I would recommend carrying an octane booster on your sled. "OCTANE" does not equal performance unless your sled requires it. The sleds that you can change switch position to run either regular or premium fuel changes the ignition timing. If your sled doesn't require premium, adding it does not equate to more power.
I run 91 cause it has no ethanol
its better gas
I've used Stabil during storage only for 25+ years with no issues.
I never said all sleds require it, I just said I think most do. Or at least have the ability to switch modes between ethonal vs non ethanol mode. But I drive polaris so I am not sure of other manufacturers. If you run non-ethanol mode, you are pretty much required to run 91.
