Your Pre Season TO DO LIST
dafalls
Haven't even thought about the sleds yet. Trying to get the cabin trimmed out and bathroom finished with tongue and groove.
Skylar
Install 2010 spindles
Install new compression adjustable shocks in front
Put on new graphics
Pull rear skid and get shocks rebuilt/charged
Polish tunnel
Talk buddy into buying different sled so I don't have to work on that %$^#@ 900 anymore!
peter
Just the basic preseason stuff for my sled and the wifes sled.
Motor rebuild for the back up/loaner sled piston went down last march.
Put boat away.
Drywall 2nd floor addition of our house.
doospunk
NOS
860 kit to start, then add turbo half way through season!
custom tunnel
Powder coat tunnel, heads, etc.
graphic wrap
well, maybe some day!
Just rebuilding shocks, changing the fluids, basic preseason maintenance. Not much new this year.
Firecatguy
Diamond drive getting new gears
power valves need a cleaning
pack to move out west
close up house for winter
new gaskets in exhaust
and exhaust springs
This may sound crazy but I'm thinkin I wanna keep this sled as close to stock as possible. I was just questioning some preseason maintanice.
Just the typical 2s stuff. Check plugs, hyfax,carbides, fluid levels,all zerks are greased,clutch belt & spare belt & run 1st tank with oil mix since such low miles
winter_time
Put on new graphics
Polish tunnel
The 900s are not all bad I love mine and it seems to work pretty well lasting longer than my powder special used too.
windingtrailgal
I'm pulling the girl card - MY ta do list is to wish for snow. Bigdaddy's is a little bit longer. The 13 year old is putting skags on the new to us mountain sled tonight instead of doing his homework. I have my studs that I bought at the Milwaukee sled show and just NOW realized my sled is in White Pine. The pole barn's exterior is done with a gravel floor yet - unheated - how am I gonna get Bigdaddy to pick up my sled for me? What if he makes ME do it??? :eek:
No major work on any of the sleds tho - just routine maintenance. It's good to be the ASSistant to the mechanic! :)
ttallin
where do i start. rebuild motor, get big bearing kit and get crank all trued up and that good stuff, new bars, new brakeline, reinforce steering post, swap tracks, new clutch parts. All of my suspension parts are ready to go greased, rebuilt shocks, new bearing in wheels.
speedo on the cat went south at the end of last season, I might look at that.
HWH: You may want to add "Check the shaft bearings" for the Cat. Speedo failure is often a tipoff that bearings are soon to follow.
I just thought of a minor detail to add to my list - Get a trailer to replace the one I sold!
Skylar
Yea, the 900 is a torque monster for sure! But, every time he rides it, I get to wonder, wth is going to go wrong with it, that I have to fix? He is a famer, so he has no time to fix it. So I do it for him. LOL.
willey
1. SHR Full 800r Rebuild. Done!!!
2. Clutches Cleaned and Tuned up by SHR. Done!!!
3. Move Steering post on my Summit.
4. Grease, Clean and Polish.
5. Snow and more snow.
6. Gas and go!!!
jmom800x
here is a short list of the top of my head.......time is getting short.
SEMI
Mount 2 New Tanks, 1 for more fuel, 1 for less stopping.
Get New Tires Mounted
Get Mud Flaps
Install New Toilet
Install New Seats
Install New Carpet
Paint
Check and Change Wheel Bearings
Change Oil
Fill All Fluids and Grease
Check All Lights
Do Inspection Of Truck
Plus More I Am Forgetting
Trailer
Install New Decking
Add Ramp
Check and Change Tires and Bearing
Check All Light and Wiring
Pack Up For 4 Months, Tools and Parts
Sled 1
Thermostat
Ski Dampeners
Cosmetics
Spare Belt
Inspection and Maintenance
Sled 2
Carb Issue To Address
Cosmetics
Spindle Bushings
Spare Motor
Get Pistons, coat them.
Iso-ed Crank
Get It Together
Nikacil spare jugs, get another set of pistons.
Dad's Sled
Lots and Lots...will it make it another season is the question.
Dads New Sled -06
Pick Up and Head West
Mom's Sled
samc
Finish in side of the new in-line trailer.... Insulate and finish the walls and install cabinets
New Graphics my sled on the Polaris
Rebuild shocks on both the Polaris and Ski Doo
New skis on the Polaris
Figure out why the 02 senser code is going off on the Polaris?
3ddirt
09' switchback
Swap ripsaw for cobra,inspect chain and gears
inspect all idler wheels,replace hyfax
install stud-boy dually carbides
grease all zirks
clean power valves
replace primary and secondary clutch springs
replace fuel filter
install mountain addiction fuel can rack from
Sled-Solutions---Thanks Paul!!
Trailer
pack bearings
adjust all brakes
ck all lights
brand new assault -
- oil it up
-spare belt
-shovel bag
-purple tow rope
-white side panels
-custom Tres 4 Traction decals
-install pipe
-skid plate
-billet throttle block
-handguard
-snow flap
-skis? maybe
-realize i have a problem and cnt leave a new sled alone :)
pack my bags and dust off the helmet cams,
load er up december 7 and head on up! cant wait!!
