Yes - or the plate the stator is mounted to.loose
as on the stator or something?
And verify timing.
itif the plugs are still getting wet or are wet , you do need to drain the block or at least make sure its drained
The plate that the Stator mounts to is adjustable for timing.if something was loose I wouldnt have spark at all would I?
I just hopped on so i might have captured everything you have done. Polaris engines are actually pretty simple. You need spark, fuel and compression to get them to run. Your sled was running great and then it stopped dead.
I had a 700 triple that did that. It was the ground wire off the cdi. On the trail I saw the loose wire and connected it to an inadequate ground. We towed it into a mechanic in big bay and he connected it where it was supposed to go. Fixed the problem.
I had a 600 triple that gradually became impossible to start. It was the crank which was common on those models. I traded the sled in for parts because I didn't want to deal with it.
Enough of my stories. If you don't have a simple ground problem and you want to use it, take it to an expert tell them what you experienced when it died.
Oh man, I "binge watched" this post a day too early.
