The sled came from dealer with high elevation kit. They are giving me the stock Arctic Cat low elevation parts. I don't want to waste my time insalling stock parts if there is a better after market alternative.This sled "should" have been set up for elevations in the "Mid-West" (0 to 3000'), however, depending on some factors, i.e., whether it was a "local" dealer set up, or a personal sellers set up, if your riding area is primarily in the Midwest, make sure it is set up for those parameters, it's easy to change out for higher elevation if or when needed.-Mezz
Not trying to knock your mechanical skills, but if you're out asking this question then you will probably not notice and/or benefit from the results of somebody else's clutch kit. Every single persons riding style is different and the sled should be clutched as such. There is nothing wrong with "stock" 9.9/10 the reason you can't do something your buddy did, or you saw Chris burandt do in a video, is because you're lacking in the skills department, and aftermarket parts don't fix that... Just my honest opinion, and there's $4000 worth of aftermarket parts on my sled...
