ezra, I did not need a longer cable, I just needed to replace the one I had. When we did the change over, a split was discovered in the throttle cable casing which was causing it to hang up on return every so often. This was re-routed to avoid that from happening again. Expensive little bugger too! Routed it up the left side of the sled (like on the M). The brake line & wiring harness were no problem either. Remember, you will need the new style M handle bars for all of this to reach properly.-Mezz
